frank.n
Met problem dual signing code in windows 2012
Hi Team,
We have built a script running in windows 2012.
Everything is fine, but when I sign code, it popup message :
Digital signing for compatibility with legacy operating systems (Windows XP/Vista) requires Windows 8 or newer.
We have checked the sign tool options:
and the digital signature options:
When I change to "Sign only for modern system...." , the digital signing has no problem, but only with "sha256"
We want dual signing, and allow our package be used in old windows OSes. So we need to select "sign for compatibility with all operation systems ...."
But it will pop up the error message above.
Can you please advise what to do to fix the problem ?
Frank
Re: Met problem dual signing code in windows 2012
Hi Frank,
Please accept my apologies for the delayed reply on this.
Could you please uninstall the current installed Windows SDk on your machine and, then download and install the latest Windows SDK available for your system and see how this works?
