david.sanda
embedded appx packages failing to install
Hello everyone, i have an unpleasant problem with the advanced installer. I have a professional version and i use the software to package
UWP appxbundle application and all its dependencies together. There is nothing more than just installing these.
The installer stopped working recently and it just returns 1603 error when it tries to launch the individual installs.
When i try to install the individual appxbundles(appx files) files manually, it works without any problem and installs correctly.
Could you please advise what to try or what to look at?
(i have a professional version of AI)
vystup.txt
(260.57 KiB) Downloaded 314 times
david.sanda
Re: embedded appx packages failing to install
The problem in question are these lines
CustomActionSchedule(Action=VCLibs_64,ActionType=1089,Source=BinaryData,Target=InstallMsix,)
MSI (s) (88:10) [16:01:57:317]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI4330.tmp, Entrypoint: InstallMsix
CustomAction VCLibs_64 returned actual error code 1603 but will be translated to success due to continue marking
Hi and welcome to our forums,
First of all I apologize for the delayed re-ply on this.
Can you please also send us the .aip (project file) by email atsupport at advancedinstaller dot com so we can investigate its settings?
