LeisureTime
Error in 16.8 integration with VS Community 2019
Since installing AI 16.8 I am getting an intermittent error as attached. I tried re-installing, and it fixed it once, but now it is back again.
Advice?
LeisureTime
Re: Error in 16.8 integration with VS Community 2019
Here is the error in the ActivityLog.xml:
SetSite failed for package [AdvInstVSIntegrationPackage]Source: 'AdvInstExtensionVSIntegration.vcs16' Description: Could not load file or assembly 'Microsoft.VisualStudio.Threading, Version=16.4.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualStudio.Threading, Version=16.4.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. File name: 'Microsoft.VisualStudio.Threading, Version=16.4.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'at Caphyon.AdvInstVSIntegration.AdvInstVSIntegrationPackage.InitializeAsync(CancellationToken cancellationToken, IProgress`1 progress)at Microsoft.VisualStudio.Shell.AsyncPackage.<>c__DisplayClass19_0.<<Microsoft-VisualStudio-Shell-Interop-IAsyncLoadablePackageInitialize-Initialize>b__1>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Microsoft.VisualStudio.Threading.JoinableTask.<JoinAsync>d__68.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()at Microsoft.VisualStudio.Services.VsTask.RethrowException(AggregateException e)at Microsoft.VisualStudio.Services.VsTask.InternalGetResult(Boolean ignoreUIThreadCheck)at Microsoft.VisualStudio.Services.VsTask.GetResult() WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
LeisureTime
I noticed that my AI version is 16.8 but the VS error references 16.4. So I went into VS Community 2019, Extensions menu, Manage Extensions, deleted Advanced Installer Extension, and then re-added it (version 16.8). I still get the same error.
ergh.
LeisureTime
Anyone? Bueller? Bueller?
We apologize for the delayed reply on this.
Could you please try this approach:
1. uninstall Advanced Installer extension for Visual Studio
2. update your Visual Studio version to the latest VS update
3. reinstall Advanced Installer extension for Visual Studio
and see if this helps you?
LeisureTime
That seems to have worked, at least on the first two startups of VS. Thanks!
You are always welcome.
