budyn321
How to set correctly setup author in properties msi file using property?
Question: How to set correctly setup author in properties msi file using property?
When I set publisher ("Product Details Tab") using property:
Author in msi file is "[|CompanyName] Next", but I would like the author to be "Company Gl Next"
Adding simple aip file as example (using last available version).
New product from Test.aip
(13.32 KiB) Downloaded 258 times
Re: How to set correctly setup author in properties msi file using property?
Thank you for the provided project.
I have tested this and I can indeed confirm that this is an issue in what regards Advanced Installer.
Unfortunately, I am not aware of any workaround for this issue.
I have forwarded this to our development team and hopefully this will be fixed in a future version of Advanced Installer. Thank you for bringing this to our attention.
I will update this thread as soon as the issue will be fixed.
This has been fixed in version 17.1 of Advanced Installer, released on May 27th, 2020.
