rafizan46
Help!! The application ran into a problem that it couldn't handle.
Hi, please help, suddenly Advance installer freeze and crash, when i try to open, i get the following error. Together i attach the file. I hope someone will be able to solve my problem. I dont know what to do :(
[SEH_AV_READ_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x007d5486]
Advanced Installer 16.7 build 4cb47c65
*** Stack Trace (x86) ***
[0x007d5486] -----
[0x0066a617] -----
[0x007ff2b3] -----
[0x007fe7f1] -----
[0x00826d78] -----
[0x00605ed3] -----
[0x00601444] -----
[0x006054e9] -----
[0x011c52a4] -----
[0x005e4441] -----
[0x77487b74] RtlGetAppContainerNamedObjectPath()
[0x77487b44] RtlGetAppContainerNamedObjectPath()
[0x00220000] MODULE_BASE_ADDRESS
SwordFish.1146pm18jan2020.aip
(723.6 KiB) Downloaded 280 times
rafizan46
Re: Help!! The application ran into a problem that it couldn't handle.
Hi, this is the last known good condition file that i backup a day before it.. I hope this will help you restore the latest one.. Thank you
rafizan46
Hi, I already solve the problem, i made some research and i find out the problem came from line 2059 to 2296. All the code is messed up and i finally get it repaired. Thanks.
I am glad the problem is solved now.
