NovaES
(urgent) Error SignTool
The digital signing of the APPDIR\MyDLL.dll file failed. Error message: 'Done Adding Additional Store
Number of errors: 1
SignTool Error: The specified timestamp server either could not be reached or
returned an invalid response.
SignTool Error: An error occurred while attempting to sign: C:\Users\fmart\AppData\Local\Temp\BUI8063.tmp\AFT8FE1.dll'
NovaES
Re: (urgent) Error SignTool
help me! it´s urgent!
Unfortunately, I can not say for sure why this happens.
In order for me to further investigate this, could you please post a screenshot of the "Digital Signature" page?
Also, could you please let me know what version of Advanced Installer your are using?
Additionally, do you encounter this issue only with the .DLL file in subject, or it fails to sign all the files?
If the issue reproduces only for the .DLL file in subject, could you please make a copy of it somewhere on your machine and try to sign it manually (using the SignTool.exe tool)?
NovaES
I use version 16.7
If I repeat the process again, it may get locked in another library or even the same one. Depending where you want to do the job
Hello Francisco,
I have had a look over the sent files and everything looked fine.
I believe that this most probably is not related to Advanced Installer, as we use the SignTool.exe tool (from Microsoft and which comes installed with the Windows SDK)
As the error suggests, this is an error in what regards the used timestamp. Here, I would suggest trying to contact certificate provider, most probably they will be able to help.
