Sahadev007
How Can I read the Log file
Hello Team,
I tried to see the log, but was unable to find out what was happening wrong in it. I have added the log file in the attached ZIP file.
Can you please have a look at it and let me know what exactly is the issue that is happening and what can be done to resolve it?
MSIf37cc.LOG
(304.7 KiB) Downloaded 255 times
Re: How Can I read the Log file
It seems that nothing is wrong with the log file.
From what I can see in it, the installation completed successfully, with no errors.
Do you encounter any errors during the installation process? If so, please give me some more details so I can better assist.
Also, for more information about reading a log file, please have a look on our "How Do I Read a Windows Installer Verbose Log File?".
Sahadev007
Hello Catlin,
Thanks for the reply...
Actually, I've an Msi package which I was installing on one machine, the installation was successful but the application icon didn't appear under "Apps" list.
But the same Msi when i tried on another machine everything works fine as well as application icon also appear..
If you want i can share the setup file with you, below link you can find the setup..
https://drive.google.com/drive/folders/ ... sp=sharing
I'VE also attached the .aip file
T2O_KKH_P.aip
(38.06 KiB) Downloaded 444 times
I have tested this scenario and everything worked as expected on my machine:
As you can see on the above screenshot, the icon is correctly displayed.
Here is how I have installed it:
- install the .MSI
- install the .APPX package that is created on the desktop
Is there something I am missing here? If so, could you please forward me a little test-case which I can use in order to reproduce this issue on our side?
