jasond66
Problem with virtual directory (web application) and existing web site
I am trying to add a web application under a custom web site that I am installing (Server -> IIS -> Sites -> [MY_WEBSITE] -> web application under that) but encountering multiple problems without error.
When I run the installer from scratch, the web site itself fails to install (files copy but nothing under IIS). When I run the installer as an upgrade of an existing install, everything installs EXCEPT for the web application. Its source folder installs fine, but no web application is generated in IIS under the existing web site.
Running 16.9. Any suggestions on how to troubleshoot?
Re: Problem with virtual directory (web application) and existing web site
Can you please send us the .AIP (project file) and a verbose log of the installation and upgrade installation to support at advancedinstaller dot com so we can investigate them? We need to check your project settings and the install logs to check for this behavior source cause.
