bottonTurn
Custom message in User Exit Dialog (UserExit)
Hi all, thanks to help on this.
How can I display a custom message based on if the user is installing or uninstalling the product, I try the approach suggest here https://www.advancedinstaller.com/user- ... itdlg.html for User exist dialog, but no luck.
Regads,
Re: Custom message in User Exit Dialog (UserExit)
Hello Diego,
In order to achieve this, you can proceed as it follows:
- first of all, please add your text to your dialog (e.g. through a "Static Text" control)
- set this control's default "Visible" attribute from true to false (so it is hidden by default)
- add a "Control Condition" for the control so it will be shown during an install
This way, the taxt will only be shown during an installation.
