hasankahrizy
problem install .NetFrameWork 3.5 offline in win 8.1
Hi
I would like to install the .NetFrameWork 3.5 offline in Windows 8.1 but will get the following error:
Deployment Image Servicing and Management tool
Version: 10.0.10240.16384
Image Version: 10.0.10240.16384
Enabling feature(s)
[==========================100.0%==========================]
Error: 0x800f081f
The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
____________________________________________________________________________
Press any Key to Exit.
I tried every way but couldn't find it
Note: I need to install offline because it may not be connected to the internet
Re: problem install .NetFrameWork 3.5 offline in win 8.1
As you may have already noticed, .NET Framework 3.5 is installed through the "Windows Features", therefore it uses (as you could see) the dism tool.
This is the default behavior Microsoft offers and I am afraid it may not be possible to install it offline.
Please let me know if there is anything else I could help you with and I will be glad to assist.
hasankahrizy
hello
very thanks for reply
That is, there is no way or tool to do this offline automatically?
I have another problem, and that sometimes, especially in a virtual machine, the appearance of the installation wizard is disrupted.
Like the picture below
Unfortunately, I am not aware of any method or tool that can do what you want.
In what regards your UI problem, I can not say for sure why this happens.
In order for me to further investigate this, could you please forward me a copy of your .AIP file by e-mail at support at advancedinstaller dot com?
