amardelli
File Permissions
Hello All,
My MSIX package installs a "files" folder within the App RootDir where a config file should be accessed with read/write permission by the app. The MSIX works properly when I sideload it locally for testing.
When I upload to MS Store for distribution the app doesn't have access to this file and some features are lost (saved settings on close, etc). Going into the Windows Apps folder, the permissions on the file in question are as follows:
Installed from MS Store.PNG (49.8 KiB) Viewed 1591 times
When sideloaded locally (and the app works normally), the permissions screen for the same file are:
installed from MSIX.PNG (48.39 KiB) Viewed 1591 times
Within Adv Installer, the permissions screen for that same file are:
Adv Inst permissions.PNG (29.13 KiB) Viewed 1591 times
In all cases my user is an admin, and even when I run the app as an admin it still doesn't work as it should.
Also, if I simply navigate to the file, edit it and try to save it, it returns a permissions error.
Can anyone assist in this? Thanks in advance.
Re: File Permissions
I have answered your other forum thread here:
viewtopic.php?f=2&t=45165&p=115587#p115587
