trims30
How to pass parameter to custom action
Have custom Action I want to use as "Launch Attached File"
File is Executable (*.exe)
How do I pass the application directory to the custom action?
I want to pass Application Directory as it appears on Folder Dialog.
Any help is appreciated
Lee
Re: How to pass parameter to custom action
In order to achieve this, you can use our predefined "Launch EXE with Working Directory" custom action. This custom action will allow you to select the working directory of your executable.
