andyeaust
Uninstall Crystal Reports Runtime before installing as new prerequisite
we have a AI-Enterprise 16.9 Project where we have to replace the "SAP Crystal Reports Runtime for .net Framework 13.0.20" with a new Release 13.0.26.
Normaly it's no Problem because we can use the UPGRADE=1 Parameter from the Install Command Line of the Prerequsite.
The Prerequisite is a feature based Package in our Project.
Problem now is, that the msi from SAP can't correctly UPGRADE it's own Package correctly (see https://wiki.scn.sap.com/wiki/display/B ... +Downloads
"If end-user use in-place upgrading from SP25 or previous version, after upgrading, they must repair the installation in Control Panel/Programs. Otherwise the ADO.Net database connection will NOT work."
Now we have to options:
1. Uninstall the old Crystal Runtime before installing the new one
2. Repair the Crystal Runtime after Upgrade
We test the "Upgrade Option" in AIP Project, but this is not uninstalling the old Crytal Runtime (don't no why)
How we can deploy this scenario or how we can run automatic repair on the upgraded Crystal Runtime.
Our AI-Setup.exe must run from UI and silent Installation
Thanks for your Help
Andreas
Re: Uninstall Crystal Reports Runtime before isntalling as new prerequisite
Hello Andreas,
To be fully honest with you, I can not say for sure why the package is not uninstalled. I will try to run few tests on our end and see what I can find.
In what regards your second scenario, if the package is an MSI, then you can run msiexec with the repair option, e.g.:
msiexec /f {product_code}
For more information about this, please have a look on our "Msiexec.exe Command Line" article ("Repair Options" section).
For instance, you can use a "Launch File" custom action that will launch the cmd.exe at the end of the installation and pass the repair parameters to the cmd.exe.
andyeaust
Re: Uninstall Crystal Reports Runtime before intalling as new prerequisite
I checked it, but it's not working because the main msiexec is running. At wich point i have to run the "Launch File" custom action?
Can i run this also on Silent Installation with setup.exe? Because the Installation of Prerequisite runs there with aipackagegainer.exe?
I checked also the Upgrade function to remove the Package. It do nothing. When is the Uninstall with Upgrade running? Before or after Feature Based Prerequsite?
Re: Uninstall Crystal Reports Runtime before installing as new prerequisite
Hello Andreas,
The custom action should be placed after the prerequisite is upgraded.
The removal through the "Upgrades" page happens after the installation of "feature-based" prerequisites.
With that being said, the custom action could be added at the end of the installation, after the "Finish Execution" action group. In addition to this, the custom action should run asynchronously, meaning that you should disable the "Wait for custom action to finish before proceeding" and "Fail installation if custom action returns an error" options.
To be fully honest with you, I am not quite sure if this will work silently. The feature-based prerequisites are treated as post-install prerequisites when the main setup is run silently. Even if the aipackagechainer.exe launches the setup asynchronously and our custom is also asynchronous, two msiexec processes can not happen at the same time.
andyeaust
Hello Catalin,
thanks for your answers. We moved the Prerequisite to Post-Install. Now it's working.
It would be better if there were an option tu run before the feauture based Prerequisite.
I am really glad everything works as expected now.
I will forward this to our development team. Most probably, there is a reason why this is currently like it is, but I will talk this through with our development team and we will see if anything can be done in this matter.
