NovAtel
Installer for Older Versions
Version 16.9 broke our installer for a UWP .appx package. My colleague built the installer using version 16.4.1 and his installer works, I build the exact same on 16.9 and get an error (attached).
We have a diff of the two project files but we're not sure which change is causing the problem.
Where can I find the installer for version 16.4.1 so that I can continue releasing.
Re: Installer for Older Versions
You can download older version of Advanced Installer by going to the "Customer Information" page:
https://www.advancedinstaller.com/custo ... ation.html
Here, please enter your license key and, once you are in your Customer Information page, please scroll down and click on the "Please select a version..." drop-down button. This will allow you to download an older version of Advanced Installer.
If possible, please let us know about your findings in what regards this.
NovAtel
I have attached the comparison of the two project files if it will help.
NovAtel
More attachments
NovAtel
More attachments
Thank you for the provided screenshots. Unfortunately, I can not say for sure why this happens.
In order for me to further investigate this issue, could you please forward me the two copies of your .AIP file (the one built with 16.4.1 and the one built with 16.9) by e-mail at support at advancedinstaller dot com?
