zmotyan
"Downloading files" progress bar issue
In Files and Folders I have a few files that are specified to download from web location.
When the installation reaches "Status: Downloading files", the progress bar
- behaves kind of correctly for smaller files (however the bar is not divided proportionally regarding the total size of all files, which can be disturbing for the user)
- but when a file is over 2GB the progress is not displayed at all. It is on 0 for a long time, then suddenly jumps to 100, while the downloading still continues.
Also if I add a large file as a Prerequisite the same happens with the progressbar while downloading the file.
Re: "Downloading files" progress bar issue
Indeed when using large downloaded files Advanced Installer has several limitations when it comes to correctly estimating the download progress. I have forwarded your feedback to our dev team and hopefully they will manage to get this behavior fixed in the future.
