aMesquita
MSIX : Read registry from another program
I am currently testing Advanced Installer for creating an MSIX package to facilitate the installation and deployment of a set of applications. I am currently facing a problem.
I added the key "MY_KEY" in HKEY_CURRENT_USER\Software\.
After installing the package, the MSIX runs a Delphi program that should display the value of this key. However, the program cannot find this key!
I used "Hover" to detect where the key is. It is in HKEY_CURRENT_USER\Wow6432Node\Software\.
Is it impossible to read a key created from an MSIX from another program?
Thanks.
Re: MSIX : Read registry from another program
I cannot say why this happens. As long as the Delphi app is installed by the MSIX package it should see and have access to the related reg key.
To fully investigate and test your install scenario, could you send us by email at support at advancedinstaller dot com the .AIP (setup project file) and a download link of the built MSIX package so we can run a few tests on our side?
