rmugione7
Remove registry value crash
Hello. On AI 16.8 and 16.9 when i try to add a Value Removal in the registry I get a crash window.
Replicated creating a new project. See images
Re: Remove registry value crash
I have tried reproducing this issue, but everything worked fine on my end.
I was thinking that perhaps you could re-install your Advanced Installer, but since you tested this with both 16.8 and 16.9, I don't think it is something related to the installation.
Could you please give me some more details about your Operating System so I can try to reproduce this on our end (I've tested this on Windows 10 1903 - Build 18362.778 and Windows 10 1909 - Build 18363.592)?
rmugione7
I have
Windows 10 Enterprise 1909
OS build 18363.778
I replicate it only on my PC.
Other 2 PC same windows build works fine all AI versions.
I tried to uninstall all AI versions and reinstall 16.8 and still crashes.
I will use the other PC.
You may consider closed this thread.
Ricardo
Hello Ricardo,
Yes, this might indeed be a problem related to your machine.
I am glad to hear it works as expected on your other machines.
