WyoDoug
.Net 4.8 installed as a Pre-requisite
Howdy, all.
We're using AI 16.4.1to build out product install and all is going very well with the exception we just upgrades to .NET 4.8 and are using the full executable delivered as part of our single.EXE install as the install source. Problem is No matter what I do it keeps asking to install the pre-requisite every time I perform an install even if .NET 4.8 is already installed.
I'm not sure what I need to do to fix this. older version of the .NET 4.X pre-requisite installed the manner worked as expected.
I'd love a suggestion to understand what I screwed up to make it not work any longer. I've tried re-adding the pre-requisite several times without success.
I;ve attached the project and would appreciate some help.
A screenshots of the install failure is also provided.
Setup.aip
(262.45 KiB) Downloaded 241 times
WyoDoug
Re: .Net 4.8 installed as a Pre-requisite
Starting with the Windows 10 May update (2019), .NET Framework is built-in the operating system (already installed by default).
When doing our check, we skip (by default) those two versions of Windows (1903 and 1909), since it is already installed there. Somehow, it seems that you have forced the installation and thefore the .NET Framework 4.8 installer throws that error (that is not thrown by your setup package, but by the .NET installer itself).
There are two scenarios which I can think of right now:
- you manually checked the two versions of Windows where .NET Framework is already installed
- you forced the installation of the prerequisite by checking the "Always install prerequisite" radio button
As in the attached screenshot, please make sure you do not have the "Always install prerequisite" radio button checked and that the 1903 and 1909 versions of Windows are unchecked from the "Supported Operating Systems" list.
WyoDoug
You nailed the solution! Thank you!.
I am really glad I could help and that everything works as expected now!
