eit
Uninstall: System variable PATH is not restored to its original value
Hi
We are using the Edit Environment Variable Dialog to set the system PATH environment variable on Window 10
The Path environment variable is set OK when installing our product (it appends our product folders to the PATH)
The problem is when we uninstall the product: the system PATH is not restored to its original value (meaning our product folders are not removed from the list)
I think that choosing the Component in the Edit Environment Variable Dialogue is meaningful.
These are the available values for component - We don't know where this come ftom;
<ROW Feature_="AIOtherFiles" Component_="start.bat"/>
<ROW Feature_="MainFeature" Component_="AI_ExePath"/>
<ROW Feature_="MainFeature" Component_="ProductInformation"/>
<ROW Feature_="MainFeature" Component_="main.properties_2"/>
<ROW Feature_="MainFeature" Component_="setup.bat_1"/>
<ROW Feature_="MainFeature" Component_="APPDIR"/>
Please help.
Eitan
Re: Uninstall: System variable PATH is not restored to its original value
Hello Eitan and welcome to Advanced Installer forums,
I have tested this on my machine (Win10) and everything worked as expected - the values were removed upon uninstall.
In order for me to further investigate this, could you please forward me a copy of your .AIP file by e-mail at support at advancedinstaller dot com?
Also, one thing I've noticed from your screenshots: please keep in mind that the when the APPDIR property resolves (at install time), it automatically ends in the "\" path separator, therefore you do not need to add 1 more to it. Let's consider the default APPDIR:
C:\Program Files\Your Company\Your Application\
As you can see, it already ends in a path separator, therefore if you add the path like this:
[APPDIR]\YourFolder
the resolved value will be:
C:\Program Files\Your Company\Your Application\\YourFolder
(notice the extra "\" before "YourFolder")
WIth that being said, when adding the above to the PATH environment variable, it should look like this:
[APPDIR]YourFolder
respectively
[APPDIR]YourFolder\YourSecondFolder
for multiple folders.
