Collins
Change Output Directory For Temporary PowerShell Files
We have customers that block any powershell files that are placed under the C:\Windows\Temp directory. It would be helpful if there was an option to choose the directory that the temporary files are extracted to. For example, when using the InstallCertificate custom action, it places the PSS files under that directory and then their antivirus application (Cylance in this instance) blocks the custom action from successfully completing.
Re: Change Output Directory For Temporary PowerShell Files
Hello Collins,
What you want to achieve can be done by taking the file and simply moving it to another directory. For instance, you can select your file, cut it (CTRL + X) and then copy it to another folder.
If you copy it to "Application Data" folder, the fille will be extracted in the %appdata% folder (WinDir\Users\<username>\AppData\Roaming)
Collins
Catalin wrote: Fri Apr 24, 2020 8:47 am Hello Collins,
Catalin,
That will not help because your built in custom action places it in that temp folder as soon as it begins and there is no way to move it once it begins. Also, your custom action is expecting it in that location:
Function AI_SetMsiProperty($name = $(throw 'AI_SetMsiProperty requires 2 arguments'), $value = $(throw 'AI_SetMsiProperty requires 2 arguments'))
"$name :<->: $value" >> $_msiPropOutFile;
&'C:\WINDOWS\TEMP\pssE07.ps1'-pfxCert "C:\WINDOWS\TEMP\vertafore.cer"
if ($LastExitCode -ne $null) {
exit $LastExitCode;
I may have misunderstood your scenario here.
I am not quite sure I understand about what custom action you are talking about here. Are you talking about the "InstallCertificate" predefined custom action?
I've ran a new test on my machine and everything seemed to be working as expected. Here are the steps I took:
- add the certificate (.cer file) as a temporary file
- cut it from the "Temp" folder (using CTRL+X) and move it to the "Application Data" folder
At this point, I have ran the installer to see if the file is extracted as expected and it was (in the %appdata% folder)
- I have now added the "InstallCertificate" custom action as a custom action with sequence. I have scheduled the custom action after the "Paths Resolution" action group in the "Wizard Dialogs Stage"
- I have the path to the certificate by inserting "[" in the "Path" field --> "File" --> select my certificate
- built and ran the setup
After checking the "certmgr.msc", I have noticed that my certificate was correctly installed.
From what I understood, this is your scenario. Please let me know if this is not what you are trying to achieve and, if so, please give me some more details so I can further investigate.
Collins
Thank you, I will give that a try.
You are always welcome!
Please let me know if you encounter any issues.
jsmith99
We have this same issue, but its for some of the other custom actions launched by AdvancedInstaller. Is there a way to control where all dynamic powershell files are generated?
I have answered your other thread debating the same issue here:
Re: Ability Specify custom folder for dynamically created powershell files
Return to “Feature Requests”
