Winchmore
Adding NEW registry with Admin rights windows 10
Hi Iam looking for a solution to install new reg entry to user PC who does not have access to the network.
User will get a reg file to install new entry on XXX i.e [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\XXX
Tried with script but it wont work without the PC admin login \PW
Cannot import RegFix.reg: not all data was successfully written to the registry. Some keys are open by the system or other processes, or you have insufficient privileges to perform this operations.
Looking for a easy solution to do this. Would you be able to advise if any off your product could do this. The pw would need to be hidden within the Exe\msi
Many Thanks for your help
Re: Adding NEW registry with Admin rights windows 10
First of all, please keep in mind that working with registries will require administration privileges.
With that being said, your setup should run as administrator. To do so, you can simply check the "Run as administrator" option from the "Install Parameters" page.
If the user is administrator, the setup will be launched with administrator privileges. If the user is not the administrator, the there will be a prompt asking for the credentials. Please note that this all happens before the installation even starts.
When the credentials are entered, the user will be able to proceed with the installation.
