yasmeenor
Questions about Floating Licence
I've a few questions regarding floating licences that I can't resolve from either the documentation or other answers in these forums. I'm trying to work out whether floating licences are the correct solution for our environment and if so how many we might need. Any help would be appreciated.
1. Does the priority setting for build servers mean that a normal user can potentially get kicked off at no notice? If so do they lose any unsaved changes?
2. We currently have several build servers for different projects, so it is potentially possible that we could be unlucky and get more than one build server requiring licences at the same time for short periods. Am I correct that there is no automatic "pause and retry" mechanism available and that builds would fail in this scenario?
3. We have developers working remotely in different timezones. If one of them happens to have left an advanced installer session open, is it possible to close the session via the licence server so that another developer can use the licence?
4. Following on from 3... If a remote developer loses internet connectivity to the licence server (which would be located in our local office) are they unable to use advanced installer?
Re: Questions about Floating Licence
Hi and welcome to our forums,
Here are my replies inline below:
1. Yes, but they will not loose any unsaved changes. They won't be able to issue any further build operations until a floating license seat becomes available. This is the only restriction. The user can continue to work with Advanced Installer to configure and save the project settings.
2. Yes, this is right.
3. No, unfortunately we do not have such option available.
4. No, in this case Advanced Installer will run in trial mode. So they can still use Advanced Installer to configure and save the project settings, but they won't be able to build the setup project. This is the only limitation.
Just let me know if you still have any further questions or doubts.
