anhy123
How to rebuild a .msi file
When I click on the Build button it doesn't always rebuild my .msi file. It appears to only rebuild it if I delete the existing .msi file or if I make changes to the configuration. For example, starting with an existing .msi file:
1) Replace one of the files in the project
2) Click on the Build button
The result is that nothing happens.
If I remove the existing .msi file and then click on the Build button, then Advanced Installer builds a new .msi file as I would expect.
How do I force Advanced Installer to rebuild the .msi file after I make changes to the file content?
Re: How to rebuild a .msi file
In order to rebuild your project, you can use the "Rebuild All" option:
