WyoDoug
Weird problem with dialogs..
We're having a very weird problem with our dialogs.
It seems the dialogs its shows in Advanced Installer aren't the ones being used by the MSI.
It's not that different just... wrong...See what is displayed within AI 16.9 and what the end user sees.
In Adv. Ins.
AI169 maintainance.png (208.52 KiB) Viewed 1709 times
On user machine.
AI169 maintainance dialog on user machine.png (73.71 KiB) Viewed 1709 times
This is the default Blue Surface install theme provided by Adv. Ins. We haven't edited it at all, so don't understand the descrepancy.
Can you help resolve this?
Re: Weird problem with dialogs..
The "Surface" theme is a custom theme created by us and it can not be used from within an MSI. In order to use the surface theme, an EXE package must be used together with the "Enhanced User Interface" option from the "Themes" page --> "Settings" tab --> "Use Enhanced User Interface" set to "Always (install, uninstall and maintenance)".
This theme uses some controls that exceed the capabilities of the Windows Installer technology (therefore of an MSI), thus those two options mentioned above are required so our EXE bootstrapper will properly render the UI.
