SimLoe
Upgrade an installed build with another build
Hi team,
in the past (using our old installer logic) we always have been offering two builds of the same project (one including an SQL Express Setup and one without SQL) and we would like to continue that approach in the future.
I have installed one build (including SQL)(e.g. version 9.0.0.12000) on a VM and then tried to install an update (e.g. version 9.0.0.12005) using the other build. When I try to run the new setup, I receive the following error: Another Version of this product is already installed. Setup cannot be completed.
What can I do to make those two builds compatible for update installations (the only differnce is the presence of the SQL Server express feature)?
Simon
Re: Upgrade an installed build with another build
Hello Simon,
Most probably, that is not caused by the builds, but by the fact that you are using the 4th field from the ProductVersion (i.e. x.x.x.12000 and x.x.x.12005).
Please have a look over the following forum thread in which I have explained why this happens and how to fix it:
Automatic upgrade old version not working
SimLoe
Hello Catalin,
I already had implemented the upgrade rule "Include maximum version in range" as you suggested here: viewtopic.php?f=2&t=45257
When I try to install a newer version of the "large" setup (including SQL) everything works fine (even though the versions only differ in the 4th part). According to your answer, shouldn't both builds behaving the same way?
However, what I don't understand is the "new Product Code" topic. I am using Azure Devops for building. So when exactly would I have to generate a new product code? Obviously not after every checkin, right?
Simon
supertrio17
Hm, interesting. But can you please try and use only 3 fields. I think that will solve your problem. Please keep us up on your topic
SimLoe
But I need to use four fields (see the linked thread) in order to be able to install an internal upgrade on our test machines. When I used three fields, I could not upgrade version 9.0.0.12000 to 9.0.0.12005.
SimLoe
Just to keep you updated: Today, I was able to install the latest small build on a machine with the big build already installed. Maybe just some special versions didn't work together... I will continue to have a look on this issue, but for now, it seems like, the thread can be closed...
Hello Simon,
Sure, please let me know if you require any assistance and I'll be glad to assist.
