Hello Ben and welcome to Advanced Installer forums,
To be fully honest with you, I am not the most familiar when it comes to Java, therefore I may need some more details about this scenario.
First of all, if I understood correctly, it is your application (the executable that we generate for your .JAR) that is failing (please correct me if I'm wrong).
Indeed, the issue seems to be the quotation.
Unfortunately, I do not have a Java application that accepts command line input. However, I have tried to pass a command line so I can see how it is written in the configuration file (.INI file), and here is the result:
- javaIni.png (67.77 KiB) Viewed 3143 times
It looks like, in the config file, the path is correctly passed (including the quotes).
Could you please check your config file and see if the path is correctly passed?
Additionally, in order for me to further investigate this, could you please forward me the following resources, by e-mail at
support at advancedinstaller dot com:
- a copy of your .AIP file
- a download link for the setup (that was built with the above mentioned .AIP)
- a test case which I can follow in order to reproduce this issue (including a list of prerequisites. For instance, beside the Java Development Kit, what else would I need to reproduce this?)
