Balaji
special character support for message box title
I have created one property containing special character under "Install parameters".
Name of property : "ProductDisplayNameShort"
Value of a property : "Installer2020|product for testing"
I have used "|" separator (i.e. special character).
Now, I want to use this property as title for message box.
Please follow below image :
I want this title for my message box. But, when I execute my MSI, on message box it is only "Installer2020" and it skips next part from "|".
Can you help me to resolve this problem?
Balaji
Re: special character support for message box title
Hello Balaji,
I have tested this and I could indeed reproduce it.
This seems to be either an issue or a limitation to our support for the MessageBox custom action.
I have forwarded this to our development team for a fix/improvement in the future.
Until then, as a workaround, you can try to generate the message box through another custom action. For instance, you can use the "Execute inline script code" to create the message box using VBS, as it follows:
prop = Session.Property("MyProp")
msgbox "Hello",0,prop
where "MyProp" is the property that you defined in the "Install Parameters" page.
Upon further investigation, it looks like the pipe character ("|") is used by the custom action itself to parse the input data.
In order for custom action to display the whole title, the pipe character should be escaped. To do so, please create your property as it follows:
Property: MyProperty
Value: My\|Value
As you can see, we have escaped the pipe character with the "\" character. This way, the title should no longer be split up.
Return to “Feature Requests”
