rafw86
Do not remove user when uninstalling
I have an installer project which consist of installations of 3 applications:
- 1 desktop wpf application
- 2 windows services which I am developing by my own as well
The services have a requirement to be installed for a specific user which I am creating by your "Users and Groups" feature when installing. I would like to keep the user when uninstalling and also do not do anything with it when upgrading. Is there any way to do so?
Other option is to help me with deleting the user completely from the system when uninstalling without reboot. Currently I am getting this effect after each new reinstallation under the C:\Users folder:
This happens because of some left NTUSER.DAT files which the deinstaller cannot clean up. For me an acceptable solution will be just not to touch the user when installed once. But if you are able to show me a way of removing the user on uninstall completely then it will be even better.
Kind regards,
Rafael
Re: Do not remove user when uninstalling
Hello Rafael,
If you want to condition the uninstall process of the user created by your setup package, you can go to "Table Editor" page --> "Install Execute Sequence" table and condition the "AI_UninstallAccounts" action.
Please note that the "Enterprise" suite (or above) is required for the "Table Editor" feature.
rafw86
Thanks, this way I was able to disable the user removal. It's not ideal but it solved my problem.
You are always welcome!
