grunzz
Multible Software Installer/ Insall Log
Hello so iam new with Advanced Installer
I want to Build a Installer its possible to: :?:
Make a multi software installer like install software 1 then 2 then 3 ..... and to see the install is going right for very software and how to? (singel installer at the end)
possible to see what the installer doing in a window (see pic)
thanks for help
Re: Multible Software Installer/ Insall Log
Yes, it is possible to achieve what you want.
To do so, you can create a main installation package and add all the required software as prerequisites in the "Prerequisites" page.
For more information about this, please have a look over our "Creating a Professional package" article, point 7 - Add prerequisites.
grunzz
Hello yes i now this Tutorial
The Question is look at the pic from the example from Microsoft installer that is what iam mean to show it like in this picture?
and its possible to show after the installer is finish the install log to see all are correct install?
thanks for help
I am not quite sure if it's possible to achieve the same behavior as the Microsoft Installer.
Yes, this is possible. In order to create an installation log, you can start the installation package with the following command line:
MSI:
msiexec.exe /i <path_to_msi> /L*V <path_to_log>
EXE:
setup.exe /L*V <path_to_log>
For more information about this, please have a look over the "How do I create an installation log?" article.
