How to create a downgradable setup
Hello guys,
Since this was requested many times in the past by our users, today we are going to create together a setup that will contain the "Downgrade" logic in it.
A downgrade basically means the ability to install an older version over a newer version, e.g.: version 1.0.0 being able to upgrade version 2.0.0.
Let's consider you have a setup for your application with the version 2.0.0.
This setup is already installed on the machine.
In order to allow a downgrade for this version, please proceed as it follows:
- open your Advanced Installer project (for version 2.0.0)
- go to "Upgrades" page
- here, please check the "Customize Advanced Installer upgrade rules" option
- under "Upgrades" section, please double click on the rule that contains the "OLDPRODUCTS" property. Here, please set the "Max. Version" field to the following value:
255.255.6555.6555
and check the "Include maximum version in range" option.
- now please double click on the rule that contains the "AI_NEWERPRODUCTFOUND" property. Here, please set the "Min. Version" field to the following value:
255.255.6555.6555
and check the "Include minimum version in range" option.
- now please go to "Product Details" page. Here, change the version of your setup, e.g.:
2.0.0 --> 1.0.0
- rebuild the project. When asked about generating a new product code, please select "Generate New".
- install the product.
Additionally, for your reference, please find attached a sample project which achieves just what I have said above:
DowngradableSetup - Sample Projects.zip
(236.99 KiB) Downloaded 2510 times
- please build the .AIP file from the "v2" folder and then run the resulted setup file.
Expected results: v2.0 should be installed (check Control Panel)
- now please build the .AIP file outside the "v2" folder and then run the resulted setup file.
Expected results: v2.0 should be uninstalled and v1.0 should be installed (check Control Panel)
Hope this will be of help.
Return to “Sample Projects”
