alphonseg
How to Open Organization Page
I'm probably missing something simple, but I can't find how to open the Organization page. I've attached a screen shot.
Where is that located?
Re: How to Open Organization Page
Please note that the "Organization" page is available only in a Professaional or higher project type. In order to upgrade your project, you can use the "Options" toolbar button.
alphonseg
Thanks, but the project type is already set to Professional. I am evaluating Professional version because I want to be able to precompile .NET applications.
This is strange. Can you please send me your project to support at advancedinstaller dot com, so I can investigate it?
alphonseg
Done.
Thank you for sending us your project.
This issue should be fixed in the latest version of Advanced Installer (17.1).
