NovAtel
SignTool Error: No certificates were found
When my colleague tries to build my .aip project he get an error message complaining about the SignTool not finding a certificate.
I am able to build from my computer and we are using the same .aip file.
Re: SignTool Error: No certificates were found
This problem may appear if the certificate configured in the "Digital Signature" page of the project is not available on your colleague's machine. In this case, he can select a certificate that is available on his machine or disable the digital signing.
NovAtel
Hi Eusebiu,
We had originally installed the certificate prior to him building the AI project.
After your response we tried reinstalling the certificate and ran a PowerShell script to verify that it was installed correctly and then tried building the AI project again and got the same message. He restarted the PC and re-installed Advanced Installer but none of these have worked.
The only thing I can think of that would be different between our AI environments is that he is using a different product Key. Would that have anything to do with it? Just a shot in the dark.
Thanks.
Did you import your digital certificate to the personal store and then selected it using the "Use from certificate store" option from the "Digital Signature" page of your project? Does it work if you use the "File from disk" option? If not, can you use that certificate to sign your package outside Advanced Installer?
