tradeweapon
"Uninstall Cleanup Wizard" Dialog Text isn't exist in Translation dictionary
I'm korean and using Pro version.
After I add Cleanup process with Uninstall Cleanup Wizard, text in cleanup dialog show not translated.
I can't find any text in Default Strings in Translation Dictionary.
Not Translated Text form is following.
"Remove [ProductName] settings and temporary files."
I want to translate this text as korean.
Can I change this?
Re: "Uninstall Cleanup Wizard" Dialog Text isn't exist in Translation dictionary
Indeed, as you have mentioned, that string is not automatically translated.
First of all, we will need to make this string a =https://www.advancedinstaller.com/user ... ed String".
To do so, please go to "Translations" page --> "Project Strings" tab --> click on "Select" --> check "User Interface".
This way, the string should appear there. After doing so, you can add your translation to it.
