Hello Alphonse,
This looks like a strange issue, indeed.
I have tried reproducing this, but I was not able to do so. Everything seemed to be working just fine on my end.
We will further investigate this scenario and I will keep you updated if any information we found proves as being useful.
Until then:
1. Could you please make sure that your solution file points to the right .AIP file?
By default, when using the
"Edit in Advanced Installer" option from our Visual Studio extension and modifying the project, upon saving the project, the extension will ask you if you want to reload the project (since it was modified).
Normally, when upgrade your project - e.g. from
"Simple" to
"Professional" - a backup copy of your .AIP file is created in the same folder.
Please make sure that the Visual Studio does not point to that project.
You can do so by right clicking on the header file (of your project) -->
"Open containing folder".
- OpenContainingFolder.png (97.71 KiB) Viewed 3963 times
2. If the above is the case, then we can try to exclude the .AIP file from the project and then readd it. To do so, you can right click on the .AIP file -->
"Exclude from Project". After doing so, you can readd the modified version of the .AIP file by right clicking on the project -->
"Add" -->
"Existing Item..." --> point to the modified version of the .AIP file.
