I asked your support and they said that this is not possible so I guess this is an Feature Request.
What I would like to do is to distribute my program in two files. The first is the exe file containing the program and installer. The second file is the license file. When I run the exe file it installs my program and copies the license file to the same directory as the program.
The reason for this is that I don´t wont to rebuild the installation package, with the right license file, everytime I´m sending a program to my customer.
If I make a package that is not build into one file I have to zip it when sending it per email. I want it to be as simple as possible for my customer. He usually is not either intrested in copying license files back and forth. 8)
Kenneth Lundström
