Zsolt Kollarits
Dynamic folders
Recently we started to use your "dynamic (synchronized) folders" feature, however now we have a problem when trying to further modify our .aip and checkin some changes to our TFS.
The problem is that the content of some of our folders are really dynamic and keep on changing, now every time if I open up our .aip, modify it, and trying to do a checkin, I see many "irrelevant" changes coming from the dynamic folders kind of. If their content was changed since out last checkin, then I will see those changes too. I'm attaching a screenshot for better understand. It makes our checkins harder to read, especially because most of them are totally independent from the dynamic folders.
Do you have any solution for us? We would like to use dynamic folders "in the background", so we don't want to always see and checkin the changes of those folders into our .aip. I hope it' understandable what I mean :)
Zsolt
Re: Dynamic folders
Hello Zsolt,
Thank you for the explanation. I believe it is clear for me what you want to achieve.
If I understand correctly, you do not want to see the modifications that were brought upon the synchronized folders in the content of the .AIP file.
Unfortunately, I am afraid that this is not possible. Every change that is done within the Advanced Installer UI should reflect in the structure of the .AIP file.
Although I understand your point and why this would be useful to you, I am not quite sure we can do much in this regard.
Please let me know if there is anything else I could help you with and I will be glad to assist.
