jedifuk
Building with mySQL 8.0 and ODBC 8.0
I have sample.aip downloaded from other thread for mySQL 5.0 and ODBC 5.0, and it worked well.
But can someone help me if I change into MySQL 8.0, (yes, I already make new prequisites) both for MySQL 8.0 (mysql-community-installer) and ODBC connector 8.0. the problem lies in "ConfigureMySQL", because it is different between mySQL 5 and 8, (where 5.0 you use mysqlinstallerconsole, and mySQL 8.0 doesn't have it).
I read mysql documentation and frankly, i still don't know how to put it in AI.
please help me how to do the "ConfiguremySQL" section (file to launch, and command line) for mySQL 8.0
thank you..
really appreciated it
Re: Building with mySQL 8.0 and ODBC 8.0
I have done some tests now by installing the "mysql-installer-community-8.0.20.0" and I noticed that the "MySqlInstallerConsole.exe" is still delivered with the installation.
For instance, if you install the server silently, like this:
msiexec /i mysql-installer-community-8.0.20.0.msi /qn
the installer console executable can be found in the following location:
jedifuk
waoww..big thanks..i believe i can't find it..LOL...
let me try again..
this product AI really great and good..
thanks
You are always welcome!
Also, thank you for your kind words!
