NigelShaw
Files & Folders
Hey
in the files & folders, its not clear which folder represents some of the windows folders. for example:
NigelShaw
Re: Files & Folders
I found a page in the help file that sort of explained it albeit, it still references a folder structure for Windows XP...
I moved all of my install folders from Program Files to CommonAppDataFolder as that seems to be for ProgramData but after building, its not that path. The install path should be C:\ProgramData\Autodesk\ApplicationPlugins\Company but instead, its D:\AppData...
i checked the organization and they are set to CommonAppDataFolder and in the Install parameters, its set to the Company path for an install path
What am i doing wrong here?
Re: Files & Folders
Hello Nacho,
Indeed, we do have an article which explains what are the paths of the folders in the "Files and Folders" page:
Paths to the folders in the "Files and Folders" page
All the above folders are predefined for Windows Installer except for the first two folders ("Application Folder" and "Application Shortcut Folder") which are proprietary for Advanced Installer. When the installation package runs, Windows Installer will automatically resolve their paths according to the target machine's configuration.
The "Application Folder" can be configured from the "Install Parameters" page and, in a default (per-machine) scenario, it is resolved to:
[ProgramFilesFolder][Manufacturer]\[ProductName]
In what regards the second thread:
As you could see in the article, both "Application Data" and "Common Application Data" folders are Windows Installer folder and they are resolved automatically according to the target machine's configuration.
The difference between those two folders is the fact that %programdata% is a per-machine location and the %appdata% is a per-user location.
Based on that, I would say that the fact that the "Common Application Folder" is resolved to %appdata% is the fact that the installation process is deployed by a user that does not have administrator rights.
Could you please try to start the installation process with administrator rights and let me know if the behavior is the same?
- for an EXE package --> right click on it --> "Run as Administrator"
- for an MSI package --> open an elevated command prompt --> run the MSI with a command line like this:
msiexec /i <path_to_your_package>
