Tac1t
Localization troubles
In my project ActionText.Description string doesn't translate to Slovak language. This string exists in default ui_sk.ail dictionary, which is provided by advanced installer and translates correctly in other projects. Every other language localization is working correctly with that string. Every other string from my project translates correctly to Slovak language, the problem is only in ActionText.Description string.
Spanish localization
Slovak localization
Slovak localization
Re: Localization troubles
First of all, I apologize for the delayed reply.
If I understand correctly, this issue is only reproducible with your current project, eveyrhting working as expected in a new project (please correct me if I'm wrong).
If this is the case, could you please forward me a copy of your .AIP file, by e-mail at support at advancedinstaller dot com so I can further investigate this?
Tac1t
Hello, this is my aip file.
C4Basic.aip
(205.73 KiB) Downloaded 241 times
Thank you for the provided file.
I managed to build your project and I was indeed able to replicate this behavior.
Unfortunately, I can not say why this happens.
I have forwarded this to our development team for further investigations.
I will update this thread once we will reach a conclusion.
Tac1t
Hello again, is there any updates about this problem?
Unfortunately, the developer in charge of this has some issues with a higher priority in queue.
As I've mentioned in my latest thread, I will update this thread as soon as we will finish investigating this.
