smrutiRanjan
IIS Components getting installed
Hi Team,
Tried to install exe generated from advanced install 15.0.1. After install found three components getting installed automatically: Request Monitor, Window authentication, Management Service. May i know if it is default behavior of advanced installer or we can restrict it also ?
Note: Adding IIS Site inside Default web site in installer with basic Application settings.
Smruti
Re: IIS Components getting installed
Hello Smruti,
Normally, if you did not select those specific components from within Advanced Installer, they should not be installed.
However, this behavior may occur if you selected a component that depends on one of those additional components.
For instance, if you selected for installation a component that relies on the "Request Monitor" component, then the role manager may install the "Request Monitor" automatically.
Other than that, I can not think of any other reason why those components would be installed automatically.
Hope this helps somehow.
smrutiRanjan
Thank you Catalin. Where i can disable the Basic window authentication in 15.0.1 advanced installer ?
Smruti
Hello Smruti,
You can select/unselect the components from "Prerequisites" page --> your role:
Windows Authentication.png (67.11 KiB) Viewed 2636 times
