thenefield
AI V17.x & MsiCmdLine
Greetings,
I have noticed an issue since upgrading to v17.x that the bootstrap executable no longer processes msi command line arguments.
The last version this worked in was 16.9.
I have since upgraded to 17.1.1 and then 17.2, with no luck.
Even if I specify the arguments at the command line, they still don't get processed (e.g. Setup.exe /L*V "C:\install.log").
Any thoughts on why this may be broke?
Re: AI V17.x & MsiCmdLine
This is really strange, indeed.
I have tested this just now and everything worked as expected on my end:
Could you please forward me, either here or by e-mail at support at advancedinstaller dot com, a sample .AIP file which I can use to build a setup that reproduces this?
thenefield
I sent the file that could reproduce this to the support@advancedinstaller.com email, but have not heard anything back.
Any word on what may be causing the issue?
Hello Trey,
First of all, please accept my apologies for such a delayed reply.
Thank you for the provided .AIP file.
I have run few tests on my end and everything worked as expected:
Could you please try to test this on a clean machine and let me know if you are still able to reproduce the behavior?
