shetty_rohan
Checking for the running process and terminating the same
Fri Feb 21, 2014 6:43 am
After looking at http://www.advancedinstaller.com/user-g ... ocess.html, I have written a sample aip file which does the following
- Checks whether the Outlook is running
- If it is running, then displays the message box
- Depending on the msgbox confirmation, terminates the process
I am facing following issues(may be I have done some mistakes), can you please help me in solving the same
- When I uninstall(Control panel->Add/remove), I do not get the message(because of which outlook.exe is not getting terminated)
- How can I stop the installation/uninstallation if the user clicks on "no" in the msgbox
I have also attached the sample aip file
Rohan
OutlookTest.aip
(12.02 KiB) Downloaded 460 times
Re: Checking for the running process and terminating the sam
Fri Feb 21, 2014 10:19 am
Hi Rohan,
This is happening because your custom actions have been added in the Wizard Dialogs Stage. So, you need to add these custom actions in the Install Execution Stage too. You can use a drag and drop operation while the SHIFT key is pressed.
You can take a look on the Windows Installer Custom Actions article which may be useful to you.
In order to achieve that you can create a simple custom action which will run only if the NO button was pressed and that custom action stops the installation. I've attached to this post a zip archive that contains a sample which implements your scenario.
DetectProcess and terminateProcess.zip
(2.98 KiB) Downloaded 483 times
shetty_rohan
Mon Feb 24, 2014 5:38 am
Thank you, it worked.
Mon Feb 24, 2014 7:38 am
You're welcome Rohan,
If there is anything else I can help with, please let me know.
Return to “Sample Projects”
