xcat
Repackager doesn't capture registry keys under Wow6432Node
I'm using Advanced Installer 17.2 (Architect licence)
When using "repackage installation" the snapshot doesn't capture registry keys under "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node"
I'm able to reproduce the problem using a reg file containing only a registry key under "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node"
Thank you for your help
Re: Repackager doesn't capture registry keys under Wow6432Node
Could you please give me some more details about this?
If I understand correctly, you are trying to repackage an application that installs some entries under the Wow6432Node. First of all, please note that the earlier mentioned node only exists on 64-bit machine, therefore, if you are doing the repackaging on a Virtual Machine, please make sure that the Operating System is of 64-bit type.
If the above is not the case, could you please give me a test-case which I can follow in order to reproduce this?
