Mel
How can i conditionally install a directory ?
I have under "Files and Folders"
Application Folder
Client Directory
Service Directory
These are 2 directories for the application that get installed on the local machine.
I have created 2 check boxes and set the property.
Is there a way I can conditionally install lets say Service Directory depending upon user selection of the checkbox ?
thanks
Re: How can i conditionally install a directory ?
For each folder you create in the "Files and Folders" page, a new component is created in the "Organization" page (with the same name as the folder).
In order to condition the installation of a folder, simply condition the installation of its' component in the "Organization" page.
Mel
The problem is if I create a directory, there is no corresponding component in the Organization. It has something like
Main Feature
x64
x32
so what i am trying to do is create a new component and move drag the associated files in there and then put the condition on that .
But it would be easier if the component was created when the folder was.
When creating a new folder, a component should also be created for it.
Could you please try to right click on your folder --> "Go to component"? This should automatically select the component for your folder in "Organization" page.
Mel
I have tried that , but the "Go To Component" option is not enabled .
This is really strange.
Could you please let me know what version of Advanced Installer you are using? I have tested this using the latest version (17.2) and everything worked as expected.
Mel
Alll sorted now.. I missed a step you outlined.
Thankyou
You are always welcome!
I am glad everything works as expected now.
