Labarr
Uninstall Cleanup for registry
There was a thread awhile ago that touched on the issue I am having, but I have been unable to successfully implement anything
viewtopic.php?t=28294
We are building a simple installer that installs a launcher. that launcher then interacts with registry keys outside of what the installer would create.
Then during the uninstall of this launcher we want to delete certain registry keys that we interacted with. We were trying to wrap our head around the Search method, but was unsuccessful
Thank you
Re: Uninstall Cleanup for registry
Could you please give me some more details about this scenario?
For instance, is there a criteria for the registry keys created by your executable? Or are the created keys' paths stored somewhere (e.g. an INI file).
For example, if there is a predefined location where all your keys are located, you can use the "Uninstall Cleanup" to remove their parent key.
In the above screenshot, let's consider EXE_KEY and EXE_KEY_2 two keys created by your executable. If we use the "Uninstall Cleanup" wizard, this should remove both keys upon uninstallation, even if they were created outside of the installation process.
Labarr
Took some time :) but the more I play with it, the more I understand. Thank you!
You are always welcome!
I am glad things are becoming easier on your end. :)
