akshay karambale
Checkbox of pre-requisite dialog
We have created one bootstrapper and it require some pre-requisites before installation of this, one for windows 7 and one for windows 8 machne.
In our case while installing bootstrapper on Windows 7 machine it first detects whether Pre-requisite is already installed or not. If its not installed
then it shows pre-requisite dialog with both checked checkbox for pre-requisites of windows 7 and windows 8.
but our requirement is, it should checked checkbox for pre-requisies of particular window(that means if machine is of Windows 7 then it only checks pre-requisite of windows 7).
can you please resolve this why both the checkboxes are getting checked for any of the windows.
Akshay
Re: Checkbox of pre-requisite dialog
Hello Akshay,
The prerequisites are both checked for installation because they are not already installed on the machine.
If you want to conditionally check/uncheck a checkbox based on a condition, you should create your own custom dialog. For more information about this, please have a look over the "How to conditionally install a prerequisite based on user selection" article.
After creating the custom dialog, you should set the default state of each checkbox to (the "Selected" parameter) to "false" and then create a "Init Event" for your checkbox that will check it based on your condition.
You can enable the "Checkbox" by setting its' property's value to the default value.
