akshay karambale
Disable Modify button from control pannel
we have created one bootstrapper EXE, It installas successfully. Our requirement is after installation whenever we trying to uninstall that bootstrapper from control pannel, the Modify button which shown after selecting our aplication from control pannel is should be disabled. How to disable that button from control pannel ? to clear my requirement i have added screen shot of that control pannel with this post with highlighting that Modify button.
Akshaye
Screenshot (11).png (343.46 KiB) Viewed 3394 times
Re: Disable Modify button from control pannel
Hello Akshay,
In order to achieve that, please go to "Product Details" page and from the "Add or Remove programs (Control Panel)" section, please check the "Disable Modify" button.
akshay karambale
hey thank you so much....!
You are always welcome, Akshay!
I am glad this helped.
