KhMi
How to handle updates without elevation
I successfully followed this https://www.advancedinstaller.com/user- ... dates.html and was able to update the installation without elevation. But I ran into 2 problems :
1. The only progress that is visible is when the download is happening, but the progress during update is missing. I noticed that the updater.exe is in the system tray and by double-clicking that, the update progress is shown. Is there a way to show the progress without going into the system tray? (NOTE: I am not using a custom exe nor msi. The one being downloaded is the full installer exe)
2. After the update, the installer was expected to run the installed application (using Launch Installed File), but it didn't. I can see the application in the Task Manager, but it is not showing or anything.
I know that both are the result of it being under the Service' context, which restricts the showing of any user interface. But is there a way to fix these two problems?
Re: How to handle updates without elevation
You are indeed, right.
Both the UIs are suppresed by the fact that you are running the setup under the "Local System Account". You can find more information about this in the following article: Interactive Services.
Unfortunately, I am afraid I am not aware of any method in which that can be avoided.
Please let me know if there is anything else I could help you with and I will gladly assist.
