akshay karambale
Source file not found error
We have created one Bootstrapper EXE. But some time after adding some new feature it builds successfully but while executting gives error "Source file not found Error." But after changing the product code it exdecute successfully. But we dont want to change the product code because it affects our upgrade and downgrade feature, can you please suggest alternative way to solve this issue and on which case it gives this error? I have attached the screen shot of this error with this post please go through this and reply me as possible as early.
thanks
Akshay
Re: Source file not found error
Hi Akshay,
I cannot say why this happens. Could you isolate the behavior on a test case or in a small sample project?
For testing purposes we always recommend to be used virtual machines with clean states so that when something goes wrong you can easily revert to a clean state of the virtual machine. This way you can also identify easier the steps into your workflow that goes wrong.
akshay karambale
Actually we are also not able to regenerate this issue and also don't know on which particular case it gives this error. But we have one observation that the same bootstrapper if we try to install on some other machine it installs successfully. I also find advanced installer comment on some once ticket regarding the same error i.e just add "ExtractFilesFirst" install parameter. Is this the proper solution? I have also attached the screen shot of your comment on that post.Please go through this and let me know your view regarding this. we are waiting for your reply.
Thanks and Regards
Akshay
Hello Akshay,
That is indeed the resolution to the problem.
Hope that will help.
