AquaComm
AI User Interface
Is it possible to alter the Advanced Installer font used in it's own interface? I find the font, size etc to be too difficult to read and would like to make it bolder and possibly larger.
Note please that I'm talking about the AI Interface itself - not the project to be installed.
Thanks.
Re: AI User Interface
Unfortunately, that is not possible.
However, you can achieve something similar by changing your monitor's scaling.
For instance, if you increase the value from under the "Change the size of text, apps and other items" section, the text from within Advanced Installer should become larger.
Hope this helps somehow.
